V70 T5 1988 maf issue Topic is solved
Twinvolvoowner
Year and Model: 1997 V70 T5
Has thanked: 2 times
Post by Twinvolvoowner »
Hi sorry if this has been covered before I'm new to all this :D
I have an issue with my t5 had an issue with it starting and then cutting out with lots of smoke which I'm sure is because of over fueling . I suspected the maf and unplugged it and car starts fine and runs . after closer inspection it looks like the maf has been replaced with a cheep alternative. I would like to replace it however it appears to have no part numbers . can anyone advise how to get a replacement without spending a fortune on a brand new genuine one . I've looked on eBay but its difficult without a part number .will any one from a similar age car work ? Or can anyone point me in the direction to find a part number .
Thanks in advance
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Bosch 0 280 217 107
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha
Post by misha »
Don't forget to remove negative battery cable for 15-20 minutes in order to reset fuel trims.
You can disconnect it while you are working on Maf replacement.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
