Sunroof loose
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
Anyone with a sunroof, i would advise checking the mountings bolts. I was cleaning my sunroof today and investigating a minor rattle/noise. I removed the plastic accordion that fell apart as it was broken anyway and very brittle and then checked the bolts which were very loose. Now my sunroof moves without the noise of clicking/breaking plastic
NOTE: the plastic accordian is purely decorative, it slides back and forth with the sunroof, when it breaks the broken pieces catch and sound like the something is breaking.
sunroof xc70
sunroof xc70
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
prwood
Year and Model: 2001 V70 2.4T
Has thanked: 9 times
Been thanked: 22 times
Post by prwood »
I'm planning to remove the sunroof glass when I reattach the front metal strip later this week, and in preparation I went ahead and ordered replacement screws and washers for the reattachment, as per the technical bulletin regarding sunroof rattle (in a previous year I had tightened the screws but didn't replace them or add washers as described):
FireShot Capture 017 - ALLDATAdiy.com - 2001 Volvo V70 2.4T L5-2.4L Turbo VIN 58 B5244T3 - B_ - www.alldatadiy.com.png
FireShot Capture 017 - ALLDATAdiy.com - 2001 Volvo V70 2.4T L5-2.4L Turbo VIN 58 B5244T3 - B_ - www.alldatadiy.com.png (106.12 KiB) Viewed 1367 times
Cars I've owned:
- 2015 to current: 2001 Volvo V70 2.4T; 2004 Honda Odyssey
- 2007 to 2015: 2002 Subaru Legacy L Wagon
- 2003 to 2016: 2001 Toyota Corolla LE
- 1999 to 2003: 1994 Toyota Camry LE
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
These screws are tricky indeed. They are coated with thread lock - I think it's the red one (stronger). But more important is they are very short and screw into an aluminum frame: it is very easy to strip the threads inside the screw hole, which is then quite a problem.
Worth verifying the alignment of the glass with the top of the roof (and also around the seal), so not too much water accumulates - it will drain past the seal, inside the tray and will block the drain tubes with dust after a while
darrylrobert
i tightened it more than 5nm, probably twice that and it seems okay
Has thanked: 1610 times
Been thanked: 4067 times
darrylrobert wrote: 21 Jan 2021, 01:37 i tightened it more than 5nm, probably twice that and it seems okay
That’s an impressively fine pitch screw.
firstv70volvo
Year and Model: V70 T5 2001
Has thanked: 52 times
Been thanked: 123 times
Post by firstv70volvo »
prwood wrote: 20 Jan 2021, 21:12 I'm planning to remove the sunroof glass when I reattach the front metal strip later this week, and in preparation I went ahead and ordered replacement screws and washers for the reattachment, as per the technical bulletin regarding sunroof rattle (in a previous year I had tightened the screws but didn't replace them or add washers as described):
The previous owner of my car took it to a shop to fix the sunroof shade and they managed to stripped two of the four sunroof bolt holes. Be very careful not to tighten these small bolts too much or you'll have to put in Helicoil inserts, which I ended up doing for all four bolt holes while the sunroof was off. It's not too bad of a job to do the inserts but another $30 for the Helicoil kit.
