Part # for left lower oil cooler hose?
rguzz
Year and Model: 1996 850 turbo
Been thanked: 25 times
Post by rguzz »
The one that is leaking is the drivers side exit line that attaches to the radiator right above the rad hose. Its short and looks accessible. I'm hoping to pluck it off there without too much angst. Think I can do that without draining anything beforehand? Thanks. 96 850t.
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
Driver side should be the transmission cooler hoses. The outlet hose should be part# Volvo 3507931
Inlet hose 31274778
https://www.fcpeuro.com/products/volvo- ... 70-3507931
https://www.fcpeuro.com/products/volvo- ... 50-9142789
I want to say the lower hose is the inlet?
rguzz
Post by rguzz »
The one I need to replace looks like this one, transmission yes thanks. https://www.fcpeuro.com/products/volvo- ... 70-3507931
rguzz
Post by rguzz »
It looks like the easiest one to replace, I did an oil cooler line while back. Do I need to drain anything? It's silly expensive of course.
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
You can do it without draining the ATF, pretty sure it causes a bit of a mess either way. That being said, if you have done an ATF refresh in a while, it wouldn't hurt to combo it. A drain and fill will take about 3.5 quarts.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
Has thanked: 1610 times
Been thanked: 4065 times
Upper one pushes oil into the radiator
Lower one flows from radiator to transmission
rguzz
Post by rguzz »
I'll do it, I think it's the only remaining (really) leak on this car. It was tricky because it drips and blows back, the hose itself just damp where it meets the lower fitting. But I finally caught it dripping on the lower radiator hose so there it is, and it's the original. Looks like the line comes with O rings and necessary bits to complete the install. I will add a small clamp to the fitting on the radiator side. Within last year I did drain and fill x3-4 was always surprised at how dark the fluid can get so quickly. Thanks!
