2008 C-70 Boot Lid Won't Close During Opening Sequence
Third generation Volvo V70 wagon and XC70, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
richyoung87
Year and Model: 2008 C70
Post by richyoung87 »
I have a 2008 C-70 where everything works in the opening sequence except the boot Lid Won't Close and it gives an error message. After waiting a few minutes, I can start the closing sequence and the boot Lid closes and the top sequence completes except the windows don't do the final closing. The dealer said the Top Motor was losing pressure and needed replacement, which I did with a refurbished motor. The dealer mechanic said they did something and it might work a few times when I got it home. It worked twice. I then replaced the top motor myself, and it worked two more times perfectly and then went back to the same problem of the boot Lid not closing during the opening sequence. So, I'm down $800 and still have an unfixed top. At least I've got a refurbished top motor. I don't have a diagnostic computer to check the Hall sensors. If it worked twice after the dealer played with it and twice after I replaced the motor, I'm thinking it can't be the motor, and I'm not sure about the #7 Hall sensor. Anybody had the same or similar problem and fixed it? Thanks
Jonesroad
Year and Model: 2015 v60
Has thanked: 13 times
Post by Jonesroad »
two years back..but did you ever resolve this?
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 193 times
Been thanked: 202 times
Post by Krons »
My research indicates the system will let you close the roof (or open) a predetermined number of times before the control unit says no more. According to the technician you can pull battery power to clear the control unit and get operational again.
08 C702.5T (sold)
The non-Swedes:
