What did you do to your Volvo S90,V90,V90 Cross Country lately?
Discussion on the exciting new 2017 Volvo cars built on the SPA platform.
paul66
Year and Model: 2015 volvo s60
Post by paul66 »
this should be a good way to exchange useful info!
I have a 2017 V90 (2.0L, I think it only comes in a 2.0) and flushed the engine with this stuff:
https://www.searchforparts.com/oil-chan ... 04t2-turbo
it is running smooth and I noticed less oil consumption. A family member ran it into the ground for only having it for 3 years or so, it felt like it was a 10 year old car!
also bought this
https://www.patrickaccessories.com/oem- ... FnZQ%3D%3D
as the floor mats were worn out.
your turn!
nedc202
Year and Model: 2018 S90
Post by nedc202 »
Staggered 22" wheels and tires
JAG_27909
Year and Model: 2017 V90 CC
Post by JAG_27909 »
I replaced the lower radiator hose along with a coolant change. However, I am having a terrible time "burping" the air out. I have searched forum but was unable to figure out what I am doing wrong re bleeding the coolant system. Any ideas would be greatly appreciated! John
JAG_27909
Post by JAG_27909 »
I replaced the lower radiator hose along with a coolant change on my 2017 V90 CC. However, I am having a terrible time "burping" the air out. I have searched forum but was unable to figure out what I am doing wrong re bleeding the coolant system. Any ideas would be greatly appreciated! John
eta76
Year and Model: XC70 2008
Post by eta76 »
Got a software update, related to DPF matters
Volvo_Update_WhatsApp Image 2021-08-24 at 14.41.32.jpeg (42.58 KiB) Viewed 2087 times
mechanic
Year and Model: 1998 V90
Has thanked: 3 times
Post by mechanic »
I own a 98 V90 with 274k+ miles and I have the same issue with the cooling system. I took the head off last year and had to replace many of the original sensors. I have gone thru two gallons of antifreeze since reassembly- somewhere somehow the pressure builds up and the only way to relieve the pressure is to loosen the expansion tank cap. (When the engine cools) Driving three or four miles causes coolant loss but don't know where? No signs on the hoses or around the hoses. I haven't been driving it often lately because it needs a fuel regulator.
This cooling issue is a puzzle tho.
'89 740 run like a top
92 940 purrs like a kitten
