White creamy paste on the oil cap...
Stewart18
- Year and Model: 2006 S60
- Has thanked: 1 time
So the other day i went to check the level on my oil stick. that seemed fine.. and then i lifted up the cap and there was quite a bit of this pasty whiteish sludge on the underside of it instead of oil. What gives?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
May want to test your PCV - yout
Stewart18
I did that test about 3wks ago with a rubber glove over the cap area and it was sucking in which is a pass. Looking online the problem is a blown gasket (hardly likely in my case) or water mixing in the oil by not driving long enough to let the engine warm up enough to evaporate the water. That seems to be my problem since i do mostly short trips.. For example my work is only 1.5 miles (3min) away and to get downtown for me is 3-4min. Longest trip i may make in a week is 20 min there and back to the store or whatever.. Point is no trip i've made in the last six mths was even 40 min long.
- SuperHerman
- Been thanked: 207 times
This is a fairly common problem in extremely cold climates. Water vapor and oil mix together and freeze forming the white creamy frozen gel.
The solution is to drive the car at operating temperature for long enough that the frozen gel does not form. Short trips don't permit the engine and all related systems to get hot enough.
So if you do a bunch of short trips in extreme cold the risk of problems is very high. Drive the car every few trips long enough to get it plenty hot. The heat will keep the gel from forming and break down any that has formed.
In the BMW world on some of there older models, more so than the Volvo world, the frozen gel would actually form a plug which resulted in the system dumping all of the oil into the engine - destroying a number of the engines completely.
- oragex
It is true a head gasket can cause that white cream, but it's not always a head gasket. May want to look inside the coolant reservoir for any floating 'oil' or darker deposits on the walls. If the PCV is good, it may also be caused by very cold weather, and possibly by the oil condition. I suggest not letting the engine idle after a cold start, I drive right away gently for the first 1-2 minutes then rev to 3000rpm to warm the engine faster so it's reaching the operating temp faster. Myself I had that white cream, I believe it was before replacing the PCV, since then I didn't notice it any more
Edit: basically saying as comment above
- 1221 Views
Last post by jonesg
- 1435 Views
Last post by JDS60R
- 2400 Views
Last post by grammagrace
- 2422 Views
Last post by erikv11
- 1648 Views
Last post by Caffeind
