Hi all,
I am having recurring issues with the ignition lock / steering wheel lock feature on a 2001 V70 T5.
Specifically, the car goes into steering wheel / ignition lock (hope i'm using the correct term here) frequently. When it does, the key will not move in the ignition. I know not to force it. I of course gently move the steering wheel and press the brake while trying to turn the key. It can take up to fifteen minutes before it finally turns over. It seems to have started after I repaired the drivers side window, but I can't be sure. The first time this happened, I was repairing that window. It happens maybe 1/4 of the time.
Ignition Lock Issues
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
sounds like the locking tab on the ignition barrel is sticking, most likely just needs a cleaning. I dont think you can take the barrel apart but you may be able to spray some lube in there?.Removal of the barrel can be a challenge because they use dome headed (anti theft) bolts. If you swap your ignition barrel you need the key and you need to swap the ID chip (RFID) inside the key. Ive done this to my 2001 as the barrel was worn and the key was used as a chew toy. I also swapped the driver door lock to match the key, also remove the Volvo ID plate or write down the VIN from the donor car.
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
- Been thanked: 504 times
Try this trick...
Written for P80 but also true for P2 cars.
DIY: 1998 S70 GLT Ignition Tumbler FREE Fix!
viewtopic.php?t=67531
- 1123 Views
Last post by volvolugnut
- 7445 Views
Last post by precopster
- 1463 Views
Last post by joevar
- 4115 Views
Last post by lummert
- 2833 Views
Last post by Mark60
