2009 Volvo S60 Turbocharger Oil Feed Line
volvomadness
Year and Model: v70 2003
Been thanked: 9 times
Post by volvomadness »
daughters car is leaking oil. front passenger side. Doesn't seem to be coming from timing belt. Need to clean it up before I can locate,
Anyone has had experience with the Turbocharger Oil Feed Line leaking oil?
Has thanked: 1609 times
Been thanked: 4064 times
The return line seems more common but it’s two copper banjo washers on the P80and P2 models
volvomadness
Thank you.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
abscate wrote: 09 Feb 2021, 05:37 The return line seems more common but it’s two copper banjo washers on the P80and P2 models
OIl return on mine is a drain pipe to the sump, gasket and O ring is the usual suspects.
Very finicky to reinstall.
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
Check your PCV system - if it is clogged or restricted the pressure will find the weakest point of exit.
Feed line is right under the water pipe. Very visible. If you cannot see the oil leak there, it’s cam seals or,very unlikely, oil pump
volvomadness
My mechanic tells me the leak was a loose bolt on the piston cooling valve. Trying to locate the piston cooling valve on line. Is it in the timing cover area. How in the hell can a bolt get loose on this part?
Ah, those mystery little ports on the right side of engine/towards rear of car.
We wondered what those are for on RN engines a few years back then someone figured it out here.
It’s not really a valve but an access cover to the piston squirters on 1999 turbo models, and later on, all models
