Combustion cylinder Before and after pics
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
Had a very good conversation with a new indie volvo shop as my usual shop seems to have closed down. Anyway we discussed my knock sensor problem and he said it could be the timing (it is adjustable on both inlet and outlet cams) or try cleaning the MAF sensor (ihave done this recently, but i might try my spare), unfortunately they dont do any type of chamber cleaning like nut blasting when i asked about carbon build up, so i will try some things myself.
Here is a before cleaning pic, i really want to poke a screwdriver in there and see how deep it is but i think thats bad?..what about when i soak it with seafoam can i use a brush or something, as long as it doesnt scratch right? I intend leaving the seafoam soak for two or three days...good or bad idea?
chamber carbon build up
inside 5 cyl.jpg (305.75 KiB) Viewed 1529 times
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
darrylrobert
So for those that dont know as i didnt, the carbon build up has a tendency to get hot and ignite the fuel mix before the spark plug causing a engine shockwave or pinging. I cant hear anything like that but read it could be happening..it also reduces the size of the chamber.
Has thanked: 1610 times
Been thanked: 4068 times
That looks a lot like mine. It won’t be too deep but keep your screwdriver away from those soft piston alloys
I had the head off so cleaning was easier
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
I've been using this in the past for cleaning various things. VERY potent. Rubber gloves, mask etc feels needed. Ruined the plastic sink in the garage 🙄
BMW 540i 2002
S70 Base 2000
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
If you can get your hands on it, Atco International's Buckaroo Engineers Solvent does a real good job of cleaning parts.
Active
Past
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
With the head off, I would try to toss the pistons to the sides, see if the compression rings move freely and are not stuck. Like pushing them them to all radial directions against the wall (small movement).
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
My concern about removing that carbon buildup in situ would be that all that gunk runs down between the piston and cylinder. Some of it will invariably wind up in the ring lands, jamming up the rings from properly operating. Some of that burnt carbon is extremely hard and may become problematic.
I would lean towards leaving it alone and resisting the urge to clean it up unless the engine is out and the pistons are on a bench. Some may disagree with me on this one.
2003 XC 70 (sold)
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
I asked the same thing last week. If your ring gap is right, where does the gunk drain to as you rinse it down?
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
Blast it out the tailpipe.
BlackBart
Post by BlackBart »
It’ll scratch up the walls.
