850 subframe conversion (c70 convertible ) Topic is solved
Is an 850 with c70 convertible subframe to harsh to daily drive ?
Yes
0
No votes
No
1
100%
Total votes: 1
Jamesmoore850T5
Year and Model: 1996 Volvo 850 T5
Has thanked: 2 times
Post by Jamesmoore850T5 »
Hi
I’m considering doing the c70 convertible subframe swap on my 850 T5 after bending my current one during a snow/kerb accident
Does anyone have any expericance with the swap?
I’m wandering if doing the swap will make my car uncomfortable/ too harsh to daily drive ? With the solid bushings and extra stiffness ect I don’t want it to make the ride so harsh that I can’t drive the car. I want this car to be my daily. My car is already lowered 30/40mm
Only reason for considering the swap is I’m in need of a subframe and atm this is the only one I can find. And it’s a good price
Thanks for any help
Has thanked: 1609 times
Been thanked: 4064 times
I think fellow countryman Cookeh can guide you on this one, best.
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
The solid bushing inserts in the convertible subframe aren't any different to the Delrin bushings used as a upgrade for the standard subframe.
You won't notice any difference in "harshness" really. Unless you are extra sensitive to that sort of thing. I noticed no harness change in my 854 when I added the Delrin.
The convertible uses the 4-bolt front control arms vs the 2-bolt in the rest, so that is something to keep in mind.
Cookeh
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
I'd have to echo Chuck's thoughts. I didn't notice any significant additional NVH, though I haven't polybushed any other suspension components. If you can live with the current NVH then you'll be fine with the subframe conversion. In my experience, if you've just slapped lowering springs onto the stock shocks then that's the greatest source of increased NVH. If your new springs are matched to your shocks then this is not an issue.
Chuck brings up another valid point, in that the C70 vert uses 4-bolt arms, which means you'll need to replace those too (and they're a minor pain compared to the 2-bolt arms!). Not enough of an issue to deter from swapping the subframes though.
Whilst you're grabbing the subframe grab the horseshoe brace too, it braces the subframe to the centre of the car, and is a nice little performance upgrade.
Jamesmoore850T5
Thanks buddy. That’s really great to here. Subframe comes with the 4 bolt control arms too with only 20k miles, as well as coming with the extra horseshoe brace
Looks like I’m all set thanks again, good first experience using this forum
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
Jamesmoore850T5 wrote: 16 Feb 2021, 14:32 Thanks buddy. That’s really great to here. Subframe comes with the 4 bolt control arms too with only 20k miles, as well as coming with the extra horseshoe brace
I've been wanting to do this to my new-ish '97 850T5, and thought I had a line on the C70 setup when an old friends' wife wrecked her convertible. Then she turned into his future ex-wife, and the idea went back into my dream folder.
Glad you found you solution.
Chuck W
Post by Chuck W »
foggydogg wrote: 17 Feb 2021, 14:55 I've been wanting to do this to my new-ish '97 850T5, and thought I had a line on the C70 setup when an old friends' wife wrecked her convertible. Then she turned into his future ex-wife, and the idea went back into my dream folder.
Just get some Delrin bushings.
