Running power to trunk for a subwoofer?
wrybread
Year and Model: 1998 S70 GLT
Has thanked: 15 times
Been thanked: 15 times
Post by wrybread »
Well a Bazooka subwoofer fell in my lap, and I installed it in my trunk, taking power from the rear cig lighter for now. It sounds terrible though, very distorted. I'm hoping it's the laughably insufficient power for a sub.
Does anyone have any tips for a routing path of, say, 10 or 8 gauge wire from the battery? And think I should run a ground too or would you tap into the chassis in the trunk? If chassis, idea for where?
Carlo the Nautic Blue 1998 S70 GLT
Previously Diego the 2000 S70, now has a blown head gasket and is awaiting the coroner
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
I had a sub in my V70 once. Grounded on one of the bolts under the covers in the rear for the taillights. S70 should have similar covers. Power ran from the battery through the firewall hole, and underneath the inside trim between the door door sill and the carpet. They lift up and there's enough space there to stash a wire or two. Your cig lighter is definitely not going to cut it.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
wrybread
Post by wrybread »
Thanks for that. Any tips on where to pass a wire through the firewall?
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
If you want low lost power cables cheap. Go to a self service junkyard and get the long battery cables out of a P2 V70, S80 or XC90 which has the battery mounted in the trunk. They run between the floor and the carpet. $1.50 per foot around here. While you are at it get the plastic conduit for the cables and fab them for the best fit you can.
Active
Past
Ocelot
Year and Model: 1998, S70
Has thanked: 61 times
Been thanked: 17 times
Post by Ocelot »
wrybread wrote: 17 Feb 2021, 19:51 Thanks for that. Any tips on where to pass a wire through the firewall?
If you open the hood and look to the upper left corner of the engine bay, below the pressure lines of the AC, you'll see a rubber plug. You can pry that plug out and if you insert a powercable through the hole, it will appear in the passengersside below the dashboard (I think you guys call it the knee bolster?).
'Hij die zonder zonde is, werpe de eerste steen. Ik buk wel'. Simon Carmiggelt
Recent car
'98 Volvo S70 2.5 10V Europa edition (Freya)
'83 Volvo 340 DLS 2.0 redblock (Loki)
Previous owned Volvo's
'96 Volvo 440 Si 1.8
'87 Volvo 340 GL 1.7
'85 Volvo 340 DL 1.4
Has thanked: 1609 times
Been thanked: 4065 times
Ocelot wrote: 20 Feb 2021, 09:50
Links of rechts?
Bedankt.....
:D
Stu70
Year and Model: 2006 Sonic VR GT
Has thanked: 34 times
Been thanked: 26 times
Post by Stu70 »
“You can pry that plug out and if you insert a powercable through the hole...”
Smokey the bear says:-
Please pass any cables THROUGH the rubber bungs or plugs, never run a cable through an unprotected hole in the fire wall or you’ll have just that - a wall ‘o fire . This also means a fuse at the battery not just a fuse at the amp.
Also be careful with some packaged ‘amp wiring kits’. They sometimes have an impressive looking big 30amp fuse but woefully under size cable buried under lots of red insulation to bulk the cables appearance.
The fuse at the battery is there to protect the cable.
The amp/sub should have its own fuse to protect itself.
1998 S70 10v BiFuel - Sold
2006 Sonic V70R - “this is going to be expensive “
RickHaleParker
Ocelot wrote: 20 Feb 2021, 09:50 You can pry that plug out and if you insert a powercable through the hole, it will appear in the passengers side below the dashboard
Don not pry the plug out. Cut an X in the center. Push the cable through. That way the rubber plug will keep the cable insulation from rubbing in the sheet metal, cutting the insulation and shorting out. Guy have burnt their vehicles to the ground by removing the plug instead of using the plug as an insulator.
After your done with the install. Dope the plug with RTV to make it watertight again.
Active
Past
Ocelot
Post by Ocelot »
Stu70 wrote: 20 Feb 2021, 12:02 “You can pry that plug out and if you insert a powercable through the hole...”
Thanks Smokey :wink: Forgive me for my incomplete instructions. I meant to say to PASS the powercable through the rubber plug, but if it's a thin cable that might get a bit tricky to get the cable into the car with the plug in place. My bad! :oops:
Recent car
