Got the battery cable resolved, now getting a P0340 cam sensor error.
Car running ok, but cold starting is taking about 5 seconds of cranking. , vs the 1/2 second before.
I’ll sort out if it is sensor or wiring by troubleshooting today. Have spare for swap. I’m going to examine wiring carefully as I was fussing with the loom a lot while I was doing the battery cable.
I had a couple of idle stalls while I was doing the cable, so the sensor may have been going out then.
1999 S70 NA Evita P0340 long cranking [Loose connector] Topic is solved
- Been thanked: 4063 times
Well, one of the short ones.
Either I pulled it or the connector is no longer locking and shook free, but I found the cam sensor loose and disconnected.
Plugged in , cleared codes, and problem solved
Cranking time now 0.5 second as before
I’ll zip tie it when the wind comes under 25 mph
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Our all-purpose excuse for when things didn't go as planned on the boat was "High winds and heavy seas."
Especially useful for electronic issues.
“Marines on board”foggydogg wrote: 20 Feb 2021, 11:24 Our all-purpose excuse for when things didn't go as planned on the boat was "High winds and heavy seas."
- 28 Replies
- 4794 Views
- 13 Replies
- 3576 Views
Last post by wizechatmgr
- 34 Replies
- 5258 Views
Last post by 800artfreed
- 15 Replies
- 6401 Views
- 51 Replies
- 5211 Views
