2004 XC70 Hard Brake Pedal, 31400693 Topic is solved
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
2004 XC70 has a very hard brake pedal after replacing a broken Brake booster vacuum switch. Any idea where the brake booster vacuum pump fuse may be? Need fuse number and location, preferring to check for blown fuse before replacing the booster pump.
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
96 850 Wagon Manual Trans & 98 V70 (gone)
95 850 Sedan Auto Trans (gone)
04 XC70 Auto (gone)
04 C70 Convert (gone)
01 C70 Convert Manual Trans (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
Here are a couple other quick things to look at that can cause the hard brake pedal.
Verify that the top cap on your new switch is actually “on” and sealing well. Also, verify that your brake booster vacuum ejector hasn’t separated. The plastic becomes brittle & the endcaps/nipples can and do detach.
Brake booster vacuum ejector link
Edit: good catch Steve, thanks!
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
Different ones for p80 and p2chassis
8677893 For P80
30744402 For P2 2005-
2001-2004 ?
8677893 For P80
2001-2004 ?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The switch stays with the connector towards the front of the car, the hose where 'Motor' is stamped goes to the vacuum pump, also push the connector all the way it. You can test the pump: in the morning before starting the engine, turn ignition to POS II and press a few times on the brakes, the pump should whirls to prime the vacuum
I want to say that this stuff came about with VVT and the elimination of SAS pump and valve.
ON cold start, the P2 engines pump cold air in by pushing VVT, which eliminates engine vacuum for the first minute or so. The pump gives you brake boost during this time.
cuhfs
Thanks to oragex's (above) video posting I realized when I put the new Brake booster vacuum switch in I had the plug in back which is backwards. flipped it around to plug in front... and problem solved. Installer error.
04 C70 Convert Auto
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
goldxc70
- Year and Model: XC70 2004
- Has thanked: 27 times
- Been thanked: 3 times
My '04 XC70 Brake booster vacuum switch also flew apart recently. Luckily, all the bits stayed in place and I put it back together using zip ties for the moment. I guess the lifetime for these switches is about 17 years. Also I assume it's a dealer only part?
Volvo only butFCP has them for about $75goldxc70 wrote: 19 Apr 2021, 18:22 My '04 XC70 Brake booster vacuum switch also flew apart recently. Luckily, all the bits stayed in place and I put it back together using zip ties for the moment. I guess the lifetime for these switches is about 17 years. Also I assume it's a dealer only part?
Junkyard or eBay, too.
Part number 31400693
- 1365 Views
Last post by Biggertuna
- 1284 Views
- 11 Replies
- 4353 Views
Last post by misha
- 1097 Views
Last post by bmdubya1198
- 3197 Views
Last post by pgill
