Hi folks,
I just purchased a S80 T6 @ 161,000 miles. It's a lovely car but it seems a bit underpowered compared to my wife's 2013 S60 T5. I assume the turbo is tired and needs a rebuild. I am planning to buy a used turbo of the same manufacture and have it rebuilt then swap it out. I have not found any info on the replacement procedure online for the P3. If anyone can point me in the right direction I would appreciate it.
Cheers
2008 S80 T6 turbo question
- SuperHerman
- Been thanked: 207 times
A tired turbo? What is that? It will either smoke or make an awful noise or whistle - a sign of failure. I am not sure you will get a boost drop that would lessen performance - and if you did you most likely would get a code.
An S80 is a bigger car than an S60.
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
You might post your P3 issue in the P3 S80 forum to get a better response. I'm not sure if the gen3 3.0L turbo (p3/2nd gen s80) is same as the gen2 2.9L tturbo or the gen1 2.8L tturbo (p2/1st gen s80). You might need a tune up. Perhaps the 2nd channel in the airbox is stuck closed (if you have that 2nd channel). Its also true what *cough* SuperHuman *cough* I mean SuperHerman said. 1st gen s80 t6 is 3,653lb, 2nd gen s80 t6 (yours) is 4,016lb, and your wife's 2013 s60 t5 is 3,548lb.Eric66 wrote: 25 Feb 2021, 06:55 Hi folks,
Cheers
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- 488 Views
Last post by dw2001v70
- 2826 Views
Last post by jimmy57
- 411 Views
Last post by Empeterson55
- 655 Views
Last post by vtl
- 2787 Views
