How to deactivate Head Light Wipers?
ddistefano
- Year and Model:
Hi! How am I to deactivate the head light wipers on a XC98? By Fuses or something else. If possible, can you give me explanations, Thanks!
- Has thanked: 17 times
- Been thanked: 35 times
If you look behind each headlight you will see a brown connector, just disconnect it. Loosen the 8mm nut on the wiper arm and place it in the park position and leave it be. From what I've read the radiator support may be in the way so take it loose if this is the case. Be careful though, these are plastic and you don't want to break them- or else, radiator can start leaking.
- 599 Views
Last post by alvinaus
- 1525 Views
Last post by trollins
- 554 Views
Last post by xanthefin
- 13 Replies
- 8433 Views
Last post by lifeofgold
- 16 Replies
- 1945 Views
Last post by erikv11
