i have so far done every single hose on the engine and replaced both heater matrix and deleted the troublesome bulkhead coupling in favour of direct fit heater hose all thats left of the original pipe work is the cut down section of metal pipes that attach to the matrix,all new and volvo o rings.
so 2 questions?
1. how is coolant still getting inside the car and same passenger footwell puddles?are there any other connections between the inside and out im missing ie on ac?
2.i want to use some seek and seal on the windscreen but need to remove the plastic trim that cover parts of the windscreen where it seals some seems to be under the front wing and im unable to see how it is secured,it looks fragile so i do not want to guess and destroy it! thanks for any advices,duke.
