I've never done Tie Rods before, but it looks pretty straight forward. The only question I have is removing the rear clamp on the inner boot. Is the clamp simply pushed off the boot? How then is then is it replaced?
Also, does anyone have the torque spec on the inner nut?
Inner Tie Rod Replacement
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
This may help a little viewtopic.php?f=9&t=88332volvooh wrote: 03 Mar 2021, 07:22 I've never done Tie Rods before, but it looks pretty straight forward. The only question I have is removing the rear clamp on the inner boot. Is the clamp simply pushed off the boot? How then is then is it replaced?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I recommend using only Oeticker clamps, zip ties are not tight enough and may let pass humidity which will rust the rack and damage the seals
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
For the bellows clamp, pretty sure it's a 56mmx7mm. Guy named Howard who has a Volvo site was selling them for a few years but is no longer. You can see them here- https://www.mk1autohaus.com/56mm-Steple ... _6605.html
Torque for tie rod inner nut is noted as 80Nm in VIDA.
- 2683 Views
Last post by manovlov
- 1393 Views
Last post by siegwam
- 924 Views
Last post by precopster
- 1226 Views
Last post by EstVolvo
- 4229 Views
Last post by jimmy57
