So, both front shocks on the blue beauty are leaking. It is harsh over bumps and lower in stance than usual. Mechanic recommends replacement of front struts and springs and I agree with him at 235 K miles on what I believe are the originals.
Here's the thing. With this degraded front strut performance, I am not getting any DIM message about suspension service needed. Is the lack of such a message under the circumstances diagnostic of a blown suspension control module (for another $1 k in parts in the mix?)
4C Misery -2006 V70R AWD Auto [ VIDA ERROR] Topic is solved
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
They’ll still “work” for a while, even after most of the oil has been evacuated. Chances are the module is ok if you can still switch modes. I dunno, 235k is a LOT for originals. If you haven’t owned it that entire span of miles I would be more than apt to guess that these are not the originals. Can you still switch between all 3 modes?
You could save some money & switch the shocks yourself. It’s not too bad a job, just gotta be positive you have your 4C wires routed correctly. If not the spinning CV shafts can wear right through them. Other than that, the job is no different than changing spring seats, you’re just swapping the shock absorber also.
The other alternative is to put in a non-adjustable shock like a lot of the “high performance” guys do. The cost is about the same and you are basically stuck in “sport” or “advanced” mode all the time.
https://www.fcpeuro.com/products/volvo- ... e-30683703
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- Been thanked: 4068 times
Is there any feedback on the Monro 4C shocks vs. Volvo
- Has thanked: 2857 times
- Been thanked: 1332 times
Monroe is Volvo
- - Pete -
Edit: They (Monroe) run the P2 4C R shocks in batches based on demand. Eventually, production will cease completely I am sure.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- RickHaleParker
- Been thanked: 979 times
Monroe is named after Monroe, MI and was bought by Tenneco, Inc. in 1977.
OEM Volvo 4C shocks and struts are rebadged Monroe 4C shocks and struts.
Active
Past
Past
- Has thanked: 311 times
- Been thanked: 817 times
Yeah, that is a disappointing. It's like we have to guess and stock up or do a last round of replacement just before the end. Or sell the car at that time!- Pete - wrote: 05 Mar 2021, 16:56 Edit: They (Monroe) run the P2 4C R shocks in batches based on demand. Eventually, production will cease completely I am sure.
On my P2 V70 R
In stock at FCP
I’ve always wondered what these things do electrically, change valving ?
- - Pete -
Pretty much, hard to believe how simple a change can result in such a dramatic handling difference. My least favorite YouTube channel did a “tear down” of a 4C shock & actually explained it alright.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- 7102 Views
Last post by Klem
- 6269 Views
Last post by Kiamaria
- 2178 Views
Last post by mrbrian200
- 13 Replies
- 2981 Views
- 4906 Views
Last post by doublebug
