ECM-6806 Turbocharger control system flow fault- flow too low
Herb Goltz
Year and Model: 04& 06 XC70, '12 s60
Has thanked: 7 times
Been thanked: 5 times
Post by Herb Goltz »
Hi All,
I just got VIDA-DiCE running today and did a quick scan of my 2004 XC70, which had a surprising number of stored codes (see attached screen cap).
The one that interested me the most was ECM-6806 Turbocharger (TC) control system flow fault- flow too low. This car has less boost than my 2006 with about the same mileage (~140k km, or 85k mi). It also has a slightly rough idle.
I have to figure out how to erase these codes and see which ones come back...
2012 s60 t5
2006 XC70
2004 XC70
Has thanked: 1609 times
Been thanked: 4064 times
Definitely clear the codes and see what comes back.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
erase is on the same screen that is showing the codes in delivery.
Just scroll down, the page is usually bigger than the computer screen so the delete button isn't visible but its down there.
Herb Goltz
Thanks! Just starting to get the hang of VIDA, as well as having to learn all the P2 acronyms...
2012 s60 t5
2006 XC70
2004 XC70
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
Herb Goltz wrote: 16 Mar 2021, 09:13 Thanks! Just starting to get the hang of VIDA, as well as having to learn all the P2 acronyms...
I've struggled through the ECM-6806, more here viewtopic.php?f=9&t=95124.
Unless your VIDA changes its mind, the issue is somewhere along the air intake -- anywhere from air box to where throttle body mounts on to intake manifold -- hoses, sensors, and valves.
Herb Goltz
Thanks for that-- it is a long read! It seems to me that I will need to have a careful look at the whole induction path-- things are really buried in these P2's compared to my old 945T...
2012 s60 t5
2006 XC70
2004 XC70
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
jonesg wrote: 16 Mar 2021, 08:29 Just scroll down, the page is usually bigger than the computer screen so the delete button isn't visible but its down there.
Or use the keys [Ctrl] + [+] / [-] to zoom the view in and out.
Active
Past
xHeart
Post by xHeart »
RickHaleParker wrote: 17 Mar 2021, 05:14
Unless someone says otherwise, ECU takes a fully charged battery to accept ERASE ALL command -- clear the stored codes. You need to plug the battery to an external battery charger/maintainer to be successful erasing.
