V70 AWD T5 1997 SMF or DMF ?
Fiodor
Year and Model: 1997 V70 2.0 T5 AWD
Has thanked: 13 times
Been thanked: 9 times
Post by Fiodor »
Hello everyone!
I'm going to replace the clutch soon, how do I know which parts I need ?
Car's from 03/97, AWD manual with B5204T3 engine (Italian T5).
Here's my VIN: YV1LW4303V2379327
Also, what should I replace while doing the clutch ?
RMS ?
Thanks for everything, this site is better than any psychotherapy (at least for fixing my car !) :mrgreen:
1997 V70 T5 2.0 AWD with welded angle gear at 240k km
1990 740 Break (dead)
kklepack
Year and Model: 2016 XC60
Has thanked: 12 times
Been thanked: 5 times
Post by kklepack »
Most likely it is SMF as DMS was introduced in 1998. Definitely do RMS no questions asked.
Fiodor
Post by Fiodor »
Called my local Volvo garage, it's a DMF...
If I want to swap to SMF what do I need ?
Flywheel and bolts + clutch kit for 850r ?
Fiodor
Post by Fiodor »
https://www.classicswede.co.uk/Whiteblo ... 61974.aspx
Would this + the FW bolts be enough ?
Also, would anyone have the P/N of the RMS ?
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
I'm pretty sure all you need to change is the flywheel itself. Everything else is the same between DMF and SMF cars. New bolts a preferred either way, of course. I recommend using the 850R clutch, like you mentioned.
That link shows that it's just for an M90 transmission, but I don't know how different that would be for FWD applications. I know a lot of the RWD guys use M56 flywheels for their white block M90 transmissions.
Assuming your 2.0 T5 uses the same seal as the rest of the white blocks (don't see why it wouldn't), the rear main seal part number is 31480636.
Fiodor
Post by Fiodor »
Should I replace the throwout bearing aswell ?
bmdubya1198
Yes, I would definitely replace that while everything is apart.
