Lo and behold a trip to the parts yard yielded a same year same type same color Volvo with near perfect front seats. I have them at home now and I'm getting them cleaned up to install. I have looked at a few Youtube vids and it looks to be straight forward, but I would like to make sure I have the procedure right:
1 - unhook the battery
2 - Pull out the original seats
3 - I have the entire donor seat with controls - seeing as how both donor car and mine are the same year, do I need to swap the control panel? Is there anything else I should swap to make the seats and seat heaters work properly, and the car computer to "accept" them?
4 - I was planning to put the seats in place (not bolt them down) plug them in and test the electrics. Is this the best way to test? Like, vs applying 12VDC to the connectors on the donor seats? I have a trickle charger I was thinking about using for a power source..
P2 (2001) V70 front seat swap
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Undo the battery 10 min ahead, for the Airbag in the seat. The torx bolt on the lower seat belt attachment: the metal piece stays at a specific position, it has a bump to align it. Very important not to tighten too strongly the bolt because it has very short threads and starts shearing early, which will reduce its strength in case of a crash. I swapped completely from the same year electric instead of my manual passenger, no issues, works perfectly (my car had already electric driver's side). To check the seat simply connect and use the switches, no way to power from battery - and you may even pop the side airbag
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 44 times
you only need to swap the module, the rest is low tech.
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
Thanks - I wasn't sure if the module was keyed to the car or not. And thanks for the ten minute warning on the battery. This is a pretty easy job but it does have a couple of land mines - like these two issues, to be aware of.
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- 219 Views
Last post by FarmallM51
- 853 Views
Last post by SuperHerman
- 3074 Views
Last post by vtl
- 482 Views
- 446 Views
Last post by benpineapple
