Headlight Ballast issue?
Mikele82
Year and Model: XC70 04 + C30 T5 08
Has thanked: 30 times
Been thanked: 3 times
Post by Mikele82 »
Hello,
Before i take the front apart, is this a ballast issue?
I've switched lamp R/L, same filcker and subsequent off on left light.
sometimes it does flicker on the right one.
might it be a fuse or is it ballast.
any recommendations on ballast?
also
if I want to convert to LED, do I even need the ballast?
video link:
show what happens 2 sec after turning lights on.
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Flickering HID is usually a electrical power issue. Check and clean the connections. Could be a high resistance dropping the voltage and current to the ballast or the bulb. If a connector is corroded you might need to replace the connector or connector terminal.
Active
Past
