an after the fact question about disconnecting the battery Topic is solved
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
Is disconnecting the main power cable at the fuse box (Big red one) just as good as disconnecting the battery clamp from the battery itself? Yeah I'm Lazy - with a wagon, there's a few layers to dig through to get to the battery..
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- RickHaleParker
- Been thanked: 978 times
Not as good.
1. Does not shut down the REM.
2. The correct order is:
Not as good.
- A. Disconnect negative terminal.
B. Disconnect positive terminal.
C. Reconnect positive terminal.
D. Turn key to POSII.
E. Reconnect negative terminal.
Active
Past
Past
azureblue
Thanks. I'm saving this. Good to know, and maybe I should initialize the car, since it's been a while..
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- 578 Views
Last post by oragex
- 676 Views
Last post by jimmy57
- 12 Replies
- 3882 Views
- 1959 Views
Last post by kippster41493
- 793 Views
Last post by oragex
