2001 S60 ETM Throttle plate movement problem
chv3ch
Year and Model: S60 2.4T 2001
Has thanked: 3 times
Post by chv3ch »
Should the throttle plate on ETM spring back to closed position when moved? Mine seems to be sticky - see video
VID_ETM_20210323_151517853.mov
(769.25 KiB) Downloaded 160 times
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
chv3ch wrote: 24 Mar 2021, 05:12 Should the throttle plate on ETM spring back to closed position when moved? Mine seems to be sticky - see videoVID_ETM_20210323_151517853.mov
watch video at 15:05 mark, spring loaded butterfly.
pbierre
Year and Model: T6 XC70s: '13 & '15
Been thanked: 12 times
Post by pbierre »
No, the throttle flap is not sprung to close. It's motor-driven with a servo-controlled motor. The ECM tells the ETB position-sensor the desired angle, then the motor drives the flap until the position-sensor is satisfied.
What can happen is that gunk builds up where the flap closes preventing full closure, and that can make the idle run lean. Cleaning the body cavity and throttle plate solves that issue.
Has thanked: 1610 times
Been thanked: 4065 times
Moved to the active S60 Forum as an active problem for digestion...
