ive figured out why my rims needs so many weights around the standard rubber valve, the rims are designed for the heavier Tyre Pressure Sensors (not mandatory in Australia).
I assume P2 cars in the US have this fitted? ive read the Volvo ones warn you if the pressure gets down to 10PSI which is way too low.
rims designed for TPMS
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 44 times
- Has thanked: 2856 times
- Been thanked: 1332 times
That a lot of weight.
TPMS required in US since 2007... "the TREAD Act requires that all vehicles produced after September 1, 2007 be equipped with a tire pressure monitoring system."
https://www.moderntiredealer.com/articl ... st%20place.The average valve stem sensor weighs between 30 and 40 grams, or 1 to 1.5 ounces, a considerable amount from the balance perspective, especially since most tire and wheels are fairly close to "balanced" in the first place.
- 1344 Views
Last post by Georgeandkira
- 5098 Views
Last post by AVOIT17
- 958 Views
Last post by mlanctot
- 920 Views
- 1379 Views
Last post by mf70
