2004 XC70 Headlights always on
altalake
Year and Model: 2004 XC70
Been thanked: 4 times
Post by altalake »
This XC70 has Xenon headlamps and the always-on lights (daylight, lights turned to off) are supposed to be the daytime running lights, not the actual headlights. The DRLs never turn on. The Xenons are always on. The daylight sensor is supposed to be one and the same as the "alarm on" LED on the dash, yes? Could this be a relay on the CEM or elsewhere? If this car had halogen headlights, this would be normal, but not supposed to work like this with Xenons.
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
This is an election in ViDA. The previous owner either had it set that way or received it that way and didn’t notice/care/know that it could be altered. It’s not a difficult task by any means, but you need ViDA/DiCE to alter lighting configuration.
The only time you should need to think about relays is if you are adding functions to a car that previously didn’t have them, such as adding fog lights to a car that didn’t come with them. As far as I know, all P2 XC70’s came with factory installed fogs.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
No something is wrong! My 1st S80 T6 had Xenon optional lights. The Xenon should automatically come on at dark via the sensor on dash. Otherwise it reverts to standard bulb type Daytime Running Lights. I imagine some lighting module is acting up. Have you had the car checked? June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
altalake
Post by altalake »
Thanks for your replies. Apparently this is not a VIDA option problem because sometimes the running lights come on when they're supposed to - but usually not even in bright sunlight. The daylight sensor is part of the alarm-active LED on the dash I believe. No errors relating to lighting show up on the cheapo aftermarket VIDA.
kcodyjr
Year and Model: 2006 S60 2.5T AWD
Has thanked: 17 times
Been thanked: 23 times
Post by kcodyjr »
Just a WAG, but could your daylight sensor be on the fritz?
5 others that came and went
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
kcodyjr wrote: 23 Apr 2021, 10:13 Just a WAG, but could your daylight sensor be on the fritz?
This is bang-on the bullseye for the Check Easy Stuff First ethos... the simple -> complex diagnostic workflow I, for one, adhere to, and champion.
Also -> Amazon link
Has thanked: 1610 times
Been thanked: 4065 times
Canada is a different market , with full time DRL mandatory, so cars made for this market might not give you the options in VIDA that Southern British Colonies get.
It’s a conspiracy to sell auto light bulbs and contaminate our precious bodily fluids, Mandrake.
altalake
Post by altalake »
I fully concur that checking the easy stuff first is the most sensible plan. Re: that daylight sensor - It is what/where exactly? Is it the very same LED on the dash that flashes to show the alarm is on? If so, it flashes just fine - which does not mean it's working as a sensor just fine. If not, where might it be?
And that sensor is connected to a circuit which is where? Anybody know? I have checked several wiring diagrams and haven't found it. Likely the CEL but maybe not.
And last of the simple things (I think), that either/or circuit (DRL or Headlights) probably goes to a relay. Possibly this one: https://www.carid.com/standard/intermot ... l=13834578
I haven't found a relay described for this function in the wiring diagrams. I lean towards this being the problem because it's intermittent - something an electromechanical device like a relay could exhibit. And there are no associated fault codes. The lights behaved just as they were supposed to when the car was with my mechanic but only rarely before or since then.
Yes, this car is Canadian issue with either DRL or headlights on and I'm not trying to defeat or modify that - just trying to not have the $100 xenon bulbs lit up 100% of the time.
EngineeringBloke
Year and Model: 2006 2.5T S60
Has thanked: 57 times
Been thanked: 39 times
Post by EngineeringBloke »
A LED is a light emitting diode (like a bulb) - it cannot act as a sensor.
I found a discussion of the location of the daylight sensor. It seems to have been located on the climate control panel at one time: https://www.swedespeed.com/threads/loca ... sor.27820/
altalake
Post by altalake »
Thanks so much. It turns out the sensor is, in fact, a 1mm x 2mm spot at the bottom of the Climate Control Module. Odd place for it, to be sure. It might just need the sludge cleaned out for it to work more reliably.
FYI, LEDs can be and are used as light sensing devices as well and it looks like the newer Volvos do make use of the alarm LED as a sunlight sensor.
Thanks again.
https://www.wikingerparts.de/en/shop/vo ... r-31288760
