OK< I see the two little press in tabs, but I don''t have the official connector release tool. I tried just pinching them in with my fingers but the connector refuses to release. Can someone tell me what the magic word, super secret grip, is to get them to let go?
Thanks in advance
P2 Fuel filter connector release
- Has thanked: 987 times
- Been thanked: 1078 times
They are likely filled with dirt. Try a spray of your favorite cleaner to flush out the dirt. I can't remember if they are pinch type or slide side ways. If pinch type get needle nose pliers. If slide type, get an open end wrench of proper size to give you some force on the small tabs.
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
Pinch type. I found some pliers that had the perfect fit for the two press in tabs. The spray was the thing that did the trick - the connector release was just really stuck and would not let go.
Solved and thanks
Solved and thanks
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- 193 Views
Last post by br0dy519
- 2289 Views
Last post by ogatrulle
- 643 Views
Last post by sugarman
- 6569 Views
Last post by BigSpud
- 598 Views
Last post by Baptiste1106
