I installed zip ties but this brought my gap to 0, and the clutch would seize up. Now I have installed 22 gauge wire, and the gap is within spec, but I’m still getting clutch disengagement after a few minutes of driving.
Any tips to get this clutch engaged on a consistent basis? Should I install thicker wire to narrow the gap to under spec?
Thanks!
Compressor clutch gap but still disengaging.
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
The power to the compressor comes in a tiny little cable im not sure wattage but it's not high. Google relay and read up about it, its not complicated.
BMW 540i 2002
S70 Base 2000
Measure the voltage at the clutch wire when it pulls in to see if it’s close to the battery voltage. You could be loosing voltage somewhere, causing the clutch to open
You have to be careful with the AC clutch onaP2, it does fancy thing like kick in on cranking for a moment to eliminate pooled refrigerant on start up. Jimmy57 knows this in more detail. If you get it too close it might never release which won’t be good
I got a gap too tight on my P80 which eventually killed it.
0.3-0.5mm , 0.6 should not go in anywhere around plate
BROOKLYN850
- Year and Model: 04 XC70
- Has thanked: 18 times
Ebay has a Valeo AC compressor for $ 150. When do we stop ( I have the same problem as you V70 2002 - tried zip ties couldn't get them in gap ) fiddling with the clutch and just put a whole new compressor (with clutch)? I don't know what to do.
- 356 Views
Last post by foggydogg
- 2712 Views
Last post by victoriaemmy
- 713 Views
Last post by Volvovlo
- 11 Replies
- 6916 Views
Last post by ThreeBear
- 738 Views
Last post by drbruno4
