hi guys,
I have just purchased a 2005 2.5 auto XC90 with 180,000kms on it with the following problem. it starts and runs fine, shifts into reverse but appears to be stuck in one gear in drive, it will do around 80kph @ 2500rpm and locks up and unlocks fine. it is showing the check engine light but has no fault messages and no ABS light. I tried manually shifting it but no effect, removed the ABS fuses , they were good, also swapped relays, also no change.
The person I bought it from had it scanned, not with Vida, and it was showing a BCM fault.
Unfortunately the car is a 4.5 nhour drive away and before I tow it home on a trailer, I thought I would ask here, can I swap the BCM with another to drive it back or do I need it matched to the ECM first?
Also, has anyone else experienced a similar fault? Thanks,
Dale
BCM fault.and no shift in drive
Marcobrick
- Year and Model: 2003 V70T5
- Has thanked: 3 times
Where in NZ are you?
I don’t think the BCM fault has anything to do with the transmission fault...unless the speed signal is completely missing. Anyway, most generic code readers are next to useless for diagnosing these cars.
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
1973 Land Rover Series 3 flat deck.
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1995 850 Turbo Wagon
1998 V70T5
Favourite line: "How hard can it be?"
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
- 2731 Views
Last post by jonesg
- 2511 Views
Last post by TripleThreat719
- 2103 Views
Last post by ChrisatXeMODeX
- 1301 Views
Last post by tightmopedman9
- 10751 Views
Last post by precopster
