for the front fender side marker lights --
azureblue
Year and Model: 2014 S60 T5
Has thanked: 16 times
Been thanked: 8 times
Post by azureblue »
Do I need a can bus type LCD (T10) ?
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
chris11211
Year and Model: 2006 s60 2.5T
Has thanked: 7 times
Been thanked: 29 times
Post by chris11211 »
The ones that come with the headlights??
If so then you'll need a clear bulb.
https://www.amazon.com/SYLVANIA-2825-Mi ... YE310AFA3J
Instructions to replace:
Drivers side
1 - Remove the air box holding the air filter
2 - Twist LEFT on a white tab it is next to the turn signal bulb, and replace
3 - Reassemble
Passinger side
1 - Remove Winsheild washer fluid pipe held in place by a T25 torx screw
2 - Remove the computer box top and side covers for more room
3 - Twist RIGHT on the white tab to remove and replace
4 - Reassemble
azureblue
Post by azureblue »
no - the one on the front fender- it's a T10
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
chris11211
Never heard of T10 on a P2. If it's not a P2 chassis Volvo then you're in the wrong section.
azureblue
Post by azureblue »
or you don't know what a side marker light is. I have the bulb I removed from the car right here in my hand. Go look at an early P2, right in front of the front door, and you will see a light housing right there.
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
chris11211
The manual states that it is called the "Side Turn Signal"; while the "Side Marker Lights" are what comes with the headlight assembely.
The correct bulb is the WY5W bulb.
https://www.amazon.com/s?k=wy5w&i=autom ... _sb_noss_1
So you are trying to replace it with LED, right?
You want to do that then more power to you. However, it's going to blink incorrectly without modification since nothing on the car is desinged with LED in mind. And it's a bit too much in terms of time and money dealing with something that is not gonna light up for the majority of the cars life.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
The one I replaced was an ordinary orange bulb, not LED.
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 44 times
Post by darylrobert »
you can replace it with LED without modification. I have tried a few LEDs including expensive ones i bought in Sweden and none are as bright as the incandescent bulbs. Im using Philips chrome bulbs, DO NOT get the early version Osram LED (on sale for a reason) with yellow covers, its a horrid faded looking colour when flashing.
