Hello,
My Auto: Volvo XC90 2.4 D5 2005year Euro3 120kw
Gearbox: Aisin Aw 50/51Sn
I have problem with my gearbox. Something not good between 3th gear and 4th gear. I added video of my problem.
This is video for my problem:
I need help. And I will wait answers.
Thank you.
Aisin 50/51SN Problem between 3th and 4th gear
- SuperHerman
- Been thanked: 207 times
Have you inspected the B4 servo? Investigate this and see if it could be the source of your issues.
I was removed b4 servo. But everything looks good.SuperHerman wrote: 18 May 2021, 20:39 Have you inspected the B4 servo? Investigate this and see if it could be the source of your issues.
Guys please help me.
- SuperHerman
Have you checked the level and condition of your transmission fluid? There should be a dipstick.
If you have done a drain and fill did you find any shiny metal particles? At your miles it is rather rare for a transmission hard part to fail. Worn clutch discs possible, but the color of your transmission fluid would be instructive. A drain and fill, if not done, should be performed. Changes may not be immediate, but you should notice some improvement if the transmission fluid has never been changed.
Regarding driveability - have you tried driving it using the manual mode to see if you can work around the issue?
If you have a proper scanner you can watch the transmission in action. It may be that you have a solenoid that is failing and/or is sticking or it could be the valve body has some bore wear causing excess pressure loss. Which solenoid is problematic can be deduced by looking up the solenoid function chart for the 50/51SN.
Assuming you have no tools to do a proper diagnosis, start by checking your fluid level and condition. If warranted change it. Try operating the vehicle in manual mode.
Oil level good.SuperHerman wrote: 19 May 2021, 08:04 Have you checked the level and condition of your transmission fluid? There should be a dipstick.
Before was very dark oil in gearbox, black colour.
Now Its new oil inside gearbox.
I flushed my gearbox two times, with gibbons method. But doesn't help.
I have VidaDice 2014D. But I'm still learning how it works.
- SuperHerman
What happens when you shift the car manually?
- Roger_850T
- Year and Model: 854T 1995
- Been thanked: 26 times
I just went through this on my V70, same transmission. You should search the site for V70 transmission issues, you'll find lots of good discussion.
To summarize though, there are a number of steps to take, keep going down the list until you fix your issue. They are:
Replace the transmission fluid, reset the counter.
Re-do the transmission adaption procedure. (Makes the Transmission Computer re-calibrate it's adaptation.)
Rebuild the valve body
Rebuild the transmission.
I just finished putting in a rebuilt valve body. I had it rebuilt by Level 10 Transmissions. https://www.levelten.com/ I'm happy with it so far, although I'm going to re-do the adaption procedure because the N-D shift is not to my liking. But I had the exact same flare and slam between 3-4 that you have, and that's now silky smooth.
I'll post links to the V70 threads if I can find them again, but meanwhile use the forum search.
Also, I believe the B4 Servo Cover issue is not applicable to you - that was just some of the early transmissions. You can confirm by checking the transmission serial number, the first three digits are the year (2 digits) and month (letter) of the transmission manufacture. The first 3 digits of the serial number on the affected transmissions will be between 01C (March 2001) and 01L (December 2001). Since your car is 2005, it should be long after the issue was fixed, unless someone replaced your transmission with an early unit.
Roger
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
05 XC90 V8 213k
- 17 Replies
- 14276 Views
- 1323 Views
Last post by dadyer
- 909 Views
Last post by alschnertz
- 11 Replies
- 2500 Views
Last post by 4sdAIR
- 2470 Views
Last post by Clemens
