Volvo 850 Non Turbo - What tf is this tube? Topic is solved
cmdz
Year and Model: 1994 940
Has thanked: 12 times
Been thanked: 4 times
Post by cmdz »
1994 - by the way
really annoyed.
My radiator broke and the shop that replaced it was so damn reckless. I got it back the next day, 5 minutes after leaving the shop - my car started to ride in the red. I pulled over let it cool off, and cant open the hood cause they broke the opening pulley. Instant sign they were just rough with it.
Anyway, the next day I brought it back and my CEL came on, they said "woops, thermestat lol" but the CEL was my problem and not related now.
I reset the CEL, and it was fine for a day, the next day came back on and is now giving me error code "EGR system flow too high in system"
so, that's what i'm trying to diagnose in reality.
but first!
WTF Is this crushed looking hose coming from something and is it really supposed to go to nothing and live here?
I took a decently bad video too if needed
cmdz
Post by cmdz »
remove battery and tray and took a better video:
any help is appreciated!
crlande
Year and Model: 240DL;850;S70
Has thanked: 1 time
Been thanked: 36 times
Post by crlande »
Hose is inlet to the S.A.S. pump and it is shaped like that!
https://www.matthewsvolvosite.com/secon ... m-diagram/
cmdz
Post by cmdz »
crlande wrote: 23 May 2021, 16:24 Hose is inlet to the S.A.S. pump and it is shaped like that!
I had just stumbled onto reading about SAS in Euro vehicles! thank you!!
Okay, so it doesn't connect to anything, just draws air in? do you know the correct way for it to sit?
crlande
Has thanked: 1 time
Post by crlande »
The upper end just takes in air from behind the headlight. It sits exactly like that in mine! The bottom end should be attached to the air pump.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
'94 doesn't have SAS pump.
It was only available on some late '96 and all '97 with M4.4 management.
Plus....you don't have inlet to upper airbox housing for sas pump hose.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
crlande
Has thanked: 1 time
Post by crlande »
Yes.... Again the mad Serbian strikes again! It is called the air pump system on our cars, used during cold starts. Your hose in correct place and connected correctly though!
cmdz
Post by cmdz »
misha wrote: 24 May 2021, 02:02 '94 doesn't have SAS pump.
I saw on all the photos for later models they have the inlet to the upper airbox.
What is this then if not that?
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
It's the same thing, hose to the air pump, but on the 94 it doesn't go to the air box it just sits there in the corner. Read the posts by crlande, everything is normal in your car.
