96 850 SW is blowing smoke and running rough. On recommendation, I replaced the catalytic converter, but no change. Took it to an auto parts store to read the codes. Got:
P1310 No DCTC definition
P0303 Cylinder 3 misfire
P0305 Cylinder 5 misfire
P0300 multiple misfire
Spark plugs are good. Any suggestions as to what I might check and/or fix?
Misfire issues?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
What color is the smoke...black or blue?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Been thanked: 4064 times
Move the coils around to see if the misfire codes change. Probably, you need two new ones
- Has thanked: 987 times
- Been thanked: 1075 times
Is this engine coil on plug or distributor ignition system? For coil on plug type check coil grounds and swap around coils to find bad coil. For distributor type, check condition of coil wires and distributor cap.
- seggs
- Year and Model: '09 S60, 04 XC70
- Been thanked: 4 times
Sounds eerily similar to a problem I had with my 04 xc70 a few months ago. In my case it ended up being a burnt valve. If you going to be switching around the ignition modules anyway, your just 5 spark plug removals away from doing a compression test. You can get a usable on for about $25 on Amazon. Then you at least know it’s not that. I could have saved the cost of 2 modules if I would have done a compression test. Also, check out the wiring to the modules. Mine had large amounts of the wire insulation dried & flaking, which I had to re-wrap.
2009 S60 2.5T FWD 155k
2008 S60 2.5T FWD 150k
2004 XC70, 220k(sold)
2005 XC90 2.5T AWD 173k(sold)
2003 S60 (sold)
- Has thanked: 2197 times
- Been thanked: 1851 times
Coil packs on plugs did not come into use until 1999 models. Car will be a distributor with plug wires to the plugs.
Check the plug condition. Also remove the distributor cap and check for damage/wear to distributor cap and rotor. Also look for oil in the base of the distributor.
Turbo or NA?
Check there is not oil running into the top of the engine from a blocked PCV system.
Also check the plug wires have not been trapped under the cover near the distributor. They can get picked and short out.
Let's try the simple stuff first before we panic about the compressions.
Turbo or NA?
- Has thanked: 311 times
- Been thanked: 817 times
What Neil said, start there, especially this:
but all of what Neil said.scot850 wrote: 03 Jun 2021, 22:04 ... Also remove the distributor cap and check for damage/wear to distributor cap and rotor. Also look for oil in the base of the distributor.
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
I see it a little differently as a compression test is easy, quick and reassuring if the numbers are in spec. If they aren't, well then you have your findings to deal with. It's kind of a make or break point in your diagnostic algorithm, and takes less time than a tune up. When my compression numbers are normal, I can then relax and take my time as I move on. Basically, it's the biggest bang for the buck, if you will. No parts to buy other than finding a tester.
Agreed. Compression test is a good thing to do also. Can be done as part of the checking the spark plug process as the plugs are out anyway.
- 19 Replies
- 10185 Views
Last post by Barledge
- 25 Replies
- 8095 Views
- 1009 Views
Last post by Brandon4TW
- 11 Replies
- 2548 Views
Last post by dimataeus
- 11 Replies
- 5895 Views
Last post by oragex
