Engine self-destruct
Zolll
Year and Model: 2004 XC70
Has thanked: 2 times
Post by Zolll »
Hi, my 2004 XC70 with 172k miles developed a sudden misfire and intermittent knocking 15 seconds before getting home. Code reader indicated a misfire on cylinder 4. I pulled the spark plug and noticed that the electrode was bent against the tip and some of the carbon deposit had been scrapped off the plug. Scoped the cylinder to find 3 small crushed metal pieces and the top of the piston completely shiny/peppered. Your opinion on what could've caused this is welcome! I currently suspect that the engine sucked-in the PCV banjo bolt ball bearing (replaced 4 years ago).
I cranked the engine with spark plugs removed and it sounded just fine, but with plugs, it was like having a golf ball in a cylinder - Now, the difficult question, the extent of damage - I am almost certain that there is some valve injury and I could probably handle fixing that. For the smart folks here, what are the chances that the piston/rods/crank is damaged? The engine was running super strong before that - wondering if it's worth pulling the head off to replace bent valve.
I appreciate your feedback and past experiences..
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 44 times
Post by darylrobert »
i heard about that ball bearing. Did you have the updated part fitted Volvo 31325709
www.matthewsvolvosite.com/forums/viewto ... 7&start=20
Zolll
Post by Zolll »
Hi - I'm not sure which version of the bolt I received when I ordered the parts. I had ordered all of the PCV parts from an online outfit at the time.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Can you get a camera in that cylinder and look around, especially at the valves? You might have a chunk out of a valve.
Zolll
Post by Zolll »
My scope won't look up towards the valve and the tiny mirror that came with the camera can't be found.. Your comment made me think that the hardened bearing would've won against the softer valve, and what I'm seeing are pieces of valve... I'll try to vacuum out the pieces and start it for a second. I might just as well pull the head and take a good look at it.
Try to trap the pieces as they get vacuumed. You will want to try to determine what they are. But you knew that.
Zolll
Post by Zolll »
Here is what I got out with a small magnet... The misfire is still there but the loud noise is gone..
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
A leakdown test will probably show intake and exh valves are leaking.
This guy went through the same thing, I think he found it cheaper to swap a used engine in.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
Zolll wrote: 04 Jun 2021, 13:27 Here is what I got out with a small magnet... The misfire is still there but the loud noise is gone..
Looks like a 22 caliber. You been taking fire recently?
Also -> Amazon link
jonesg
Post by jonesg »
the check valve is a slug, not a round ball as most say.
