Burning smell from AC vents then went away...
aaronlife
- Year and Model: 2010 Volvo XC60
- Has thanked: 1 time
- Been thanked: 2 times
Had been driving the 2010 xc60 111,000 miles with ac on working fine. Stopped to wash the car (no water under hood as far as I know). Started it back up and was getting a burning smell from the vents. Popped the hood, the ac clutch was not engaging, it was sort of stopping and starting, and there was a burning smell from the ac clutch area. Turned off the ac. Then turned it back on and it's been normal since so far... AC blows cold. Is this the sign of a failing/slipping clutch or seizing compressor? I couldn't tell if the burning was from the clutch or the belt was getting hot (though it did look like the pulley was spinning). I can get a used compressor for $185 (lifetime warranty from erie vovo) and hope for an indy to put it in, or a new clutch for $283, if someone will do that, or go aftermarket or new oem and then it gets pricier... Any thoughts or experiences to share? Thank you.
- RickHaleParker
- Been thanked: 978 times
Clean for debris around the blower fan. I could of been something locking up the blower fan.
Active
Past
Past
- 373 Views
Last post by DavidE7
- 631 Views
Last post by Ozark Lee
- 3118 Views
Last post by Clemens
- 40 Replies
- 10913 Views
- 12 Replies
- 3032 Views
Last post by Jibbaman150
