TLDR: I want to find a used but broken Haldex 4 pump in the Denver area to fix my mistake.
Greetings all. I'm an idiot. I bought a 2013 XC90 a few months ago. That part doesn't make me an idiot. After reading posts and watching videos and bookmarking gobs of pages since buying it, I have been doing all the 150k mile service stuff: water pump, upper and lower radiator hoses, tensioner, pulley, oil change, drain and fill on the transmission, air filter, angle gear fluid, rear diff fluid, haldex fluid and filter.
I just removed the haldex pump and tried to take it apart to clean it like this guy does starting around 5:40
Unfortunately, my housing was stuck so I tapped it progressively harder until it came apart. When it did, a chunk of the magnet from the housing was stuck to the motor. It makes me wonder if it was actually working if it was stuck.
Anyway, before I order a new one, or try to get one from a junkyard, does anyone have a broken one laying around in the Denver area I could get? It seems the housings are normally not the problem.
WTB Haldex pump
trickyrabbit
- Year and Model: 2013 XC90
trickyrabbit
List of compatible vehicles:
XC90 Volvo XC90 (Gen 1)
Drivetrain: AWD
2009 Volvo XC90 3.2 Sport Utility 3.2L L6 VIN:98 B6324S Automatic Differential Oil Pump
2009 Volvo XC90 V8 Sport Utility 4.4L V8 B8444S Automatic Differential Oil Pump
2010 Volvo XC90 3.2 Sport Utility 3.2L L6 VIN:98 B6324S Automatic Differential Oil Pump
2010 Volvo XC90 V8 Sport Utility 4.4L V8 B8444S Automatic Differential Oil Pump
2011 Volvo XC90 3.2 Sport Utility 3.2L L6 VIN:95 B6324S5 Automatic Differential Oil Pump
2011 Volvo XC90 V8 Sport Utility 4.4L V8 B8444S Automatic Differential Oil Pump
2012 Volvo XC90 3.2 Sport Utility 3.2L L6 VIN:95 B6324S5 Automatic Differential Oil Pump
2013 Volvo XC90 3.2 Sport Utility 3.2L L6 VIN:95 B6324S5 Automatic Differential Oil Pump
2013 Volvo XC90 3.2 R-Design Sport Utility 3.2L L6 VIN:95 B6324S5 Automatic Differential Oil Pump
2014 Volvo XC90 3.2 Sport Utility 3.2L L6 VIN:95 B6324S5 Automatic Differential Oil Pump
2014 Volvo XC90 3.2 R-Design Sport Utility 3.2L L6 VIN:95 B6324S5 Automatic Differential Oil Pump
S80 Volvo P3 Chassis
2009 Volvo S80 V8 Sedan 4.4L V8 B8444S Automatic Differential Oil Pump
2009 Volvo S80 T6 Sedan 3.0L L6 B6304T2 Automatic Differential Oil Pump
2010 Volvo S80 T6 Sedan 3.0L L6 B6304T2 Automatic Differential Oil Pump
2010 Volvo S80 V8 Sedan 4.4L V8 B8444S Automatic Differential Oil Pump
2011 Volvo S80 T6 Sedan 3.0L L6 VIN:90 B6304T4 Automatic Differential Oil Pump
2012 Volvo S80 T6 Sedan 3.0L L6 VIN:90 B6304T4 Automatic Differential Oil Pump
XC70 Volvo P3 Chassis
2009 Volvo XC70 3.2 Wagon 3.2L L6 VIN:98 B6324S Automatic Differential Oil Pump
2009 Volvo XC70 T6 Wagon 3.0L L6 B6304T2 Automatic Differential Oil Pump
2010 Volvo XC70 3.2 Wagon 3.2L L6 VIN:98 B6324S Automatic Differential Oil Pump
2010 Volvo XC70 3.2 Wagon 3.2L L6 B6324S2 Automatic Differential Oil Pump
2010 Volvo XC70 T6 Wagon 3.0L L6 B6304T2 Automatic Differential Oil Pump
2011 Volvo XC70 3.2 Wagon 3.2L L6 VIN:94 B6324S4 Automatic Differential Oil Pump
2011 Volvo XC70 3.2 Wagon 3.2L L6 VIN:95 B6324S5 Automatic Differential Oil Pump
2011 Volvo XC70 T6 Wagon 3.0L L6 VIN:90 B6304T4 Automatic Differential Oil Pump
2012 Volvo XC70 3.2 Wagon 3.2L L6 VIN:94 B6324S4 Automatic Differential Oil Pump
2012 Volvo XC70 3.2 Wagon 3.2L L6 VIN:95 B6324S5 Automatic Differential Oil Pump
2012 Volvo XC70 T6 Wagon 3.0L L6 VIN:90 B6304T4 Automatic Differential Oil Pump
XC60 Volvo P3 Chassis
2010 Volvo XC60 T6 Sport Utility 3.0L L6 B6304T2 Automatic Differential Oil Pump
2010 Volvo XC60 3.2 Sport Utility 3.2L L6 VIN:98 B6324S Automatic Differential Oil Pump
2010 Volvo XC60 3.2 Sport Utility 3.2L L6 B6324S2 Automatic Differential Oil Pump
2010 Volvo XC60 T6 R-Design Sport Utility 3.0L L6 B6304T2 Automatic Differential Oil Pump
2011 Volvo XC60 3.2 Sport Utility 3.2L L6 VIN:94 B6324S4 Automatic Differential Oil Pump
2011 Volvo XC60 3.2 Sport Utility 3.2L L6 VIN:95 B6324S5 Automatic Differential Oil Pump
2011 Volvo XC60 T6 Sport Utility 3.0L L6 VIN:90 B6304T4 Automatic Differential Oil Pump
2011 Volvo XC60 3.2 R-Design Sport Utility 3.2L L6 VIN:94 B6324S4 Automatic Differential Oil Pump
2011 Volvo XC60 3.2 R-Design Sport Utility 3.2L L6 VIN:95 B6324S5 Automatic Differential Oil Pump
2011 Volvo XC60 T6 R-Design Sport Utility 3.0L L6 VIN:90 B6304T4 Automatic Differential Oil Pump
2012 Volvo XC60 3.2 Sport Utility 3.2L L6 VIN:94 B6324S4 Automatic Differential Oil Pump
2012 Volvo XC60 3.2 Sport Utility 3.2L L6 VIN:95 B6324S5 Automatic Differential Oil Pump
2012 Volvo XC60 T6 Sport Utility 3.0L L6 VIN:90 B6304T4 Automatic Differential Oil Pump
2012 Volvo XC60 T6 R-Design Sport Utility 3.0L L6 VIN:90 B6304T4 Automatic Differential Oil Pump
S60 Volvo P3 Chassis
2011 Volvo S60 T6 Sedan 3.0L L6 VIN:90 B6304T4 Automatic Differential Oil Pump
2012 Volvo S60 T6 Sedan 3.0L L6 VIN:90 B6304T4 Automatic Differential Oil Pump
Drivetrain: AWD
- Has thanked: 2856 times
- Been thanked: 1332 times
Hi TR. I contacted the regionally-famous Volvo guy Brett Borders, and he said "I don’t have a known good one and I can order a new aftermarket or OEM one
He works at Swedish Motors in Boulder. So there's that.
Moved to Classifieds, retitled.
trickyrabbit
Thanks Matt.
As an update, I ordered a Dorman pump from Amazon for $200. I later read that some people have had poor results with dorman pumps. This morning I put the cover back on the pump and tested it with leads and it still runs, so maybe I'll just reinstall it.
trickyrabbit
You know, I would take a known bad one. I'm just going to steal the metal cover off of it.matthew1 wrote: 11 Jun 2021, 11:07 Hi TR. I contacted the regionally-famous Volvo guy Brett Borders, and he said "I don’t have a known good one and I can order a new aftermarket or OEM one".
trickyrabbit
One more update. I bought a used rear differential and AOC from a junkyard for $150. I'll steal the pump off and keep the rest around for spare parts. I'll also return the Dorman.
- Has thanked: 311 times
- Been thanked: 817 times
Good move!
