Howdy Volvo experts!
When I started the car today, it wasn't as smooth as usual. Felt it was choking. Then had this continuous revving up and down. It continued for a while then went away (sometimes it doesn't go away and continues actually). I tried to start the car again multiple times and got the same behavior.
Anyone had a similar behavior? Any thoughts what could be the problem?
Here's the video I recorded:
Help with erratic revving up and down
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
Only had it once when the weather was very hot, drove 45 minutes and it was idling that when I arrived, 3 hrs later after cooling down it was normal again.
Only happened the one time.
You might want to check for codes.
- RickHaleParker
- Been thanked: 979 times
Ambient Temperature related ... Ambient Temperature sensor?hajjat wrote: 15 Jun 2021, 20:04 Yeah in the past it happened when the weather was very hot; it's close to 90 these days in CA, so...
Try cleaning the MAF sensor which does double duty as the Intake Air Temperature sensor.
Active
Past
Past
- kcodyjr
- Has thanked: 17 times
- Been thanked: 23 times
Sounds like what happens when the IAC is on the fritz. Do P2's have one?
5 others that came and went
- Been thanked: 504 times
You have 173K miles on the odometer.
You should clean the throttle body.
I wrote a DIY in forum, basically you can slide the TB out to the driver side for cleaning.
No need to remove the Intake manifold to remove the TB.
- hajjat
- Year and Model: 04 Volvo XC70
- Has thanked: 1 time
Cool. Found your DIY post viewtopic.php?f=10&t=78629. I'll give it a shot and see if that solves the issue. Never done it before, hope it goes smoothly (n00b here)!You should clean the throttle body. I wrote a DIY in forum, basically you can slide the TB out to the driver side for cleaning
No, no codes.Sounds like what happens when the IAC is on the fritz. Do P2's have one?
Never done that before either. Let me buy a cleaner and try it out.Try cleaning the MAF sensor which does double duty as the Intake Air Temperature sensor.
Thanks everyone for the great insights, I'll try these out and let you know how it goes!
- RickHaleParker
Not a cleaner. MAF cleaner and nothing other them MAF cleaner.hajjat wrote: 15 Jun 2021, 23:20 Never done that before either. Let me buy a cleaner and try it out.
Active
Past
Past
On a turbo , that’s probably loose induction somewhere. Start at the air cleaner, and work your way through each clamp and hose looking for loose stuff. Then go back and remove each piece looking for holes
This will take about 2 hours, total.
- 1785 Views
Last post by elmhome
- 730 Views
Last post by linzrs711
- 890 Views
Last post by difflock54
- 768 Views
Last post by JohnnyD
- 40 Replies
- 5565 Views
Last post by kaneelschep
