2004 Xc70 cross county
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Alex5150
Year and Model: 2004 xc 70
Post by Alex5150 »
My volvo seems to do this only when its very hot outside .105 last time today it was 110. .my volvo makes a thump under the car sounds like the tranny ..then shuts off ..then comes back on again..but instead of having everything working normal .i have no lites no power .windows etc.and it runs like its running on only a few cylinders weak.. Someone told me it was limp mode .anyway it got me home .it flickers back and forth.but everytime it does it makes a big thump. Does anbody know what the problem is.
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
make sure the cooling fan is working in the computer box next to the steering fluid reservoir.
Air is supplied from the cabin so it helps to have the A/C turned on to cool the computer.
motormikeyman
Year and Model: 2004 XC70 AWD
Been thanked: 8 times
Post by motormikeyman »
You are probably experiencing a heat related CEM failure. You may hear relays on it clicking when this failure occurs, it is under the dash above your left foot. Clunk in trans feels like you are running over a brick, transmission goes into limp home mode, stalls- no start condition, no tach or speedo, ABS failure warning, no sunroof or power windows, no AC. Xemodex has a good diagnostic procedures for this issue on their website.
'94 940 wagon, 220K miles- sold to a guy who then drove it to Oklahoma
'99 XC70 AWD, 210K miles- trans went
'04 XC70 AWD, 196K miles- still going strong
'06 S40 sedan, 150K miles- went with the ex
Alex5150
Post by Alex5150 »
Thanks for your advice ..
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Second the CEM failure, but first measure your battery and check all connections. You can look at the CEM with a flash light from under the dash for dry traces of leaks, or remove for further inspection if you can lift the wiper arms
Has thanked: 1506 times
Been thanked: 3819 times
Ten 2004 was known for a heat soak problem in the CEM. Thread maybe 2 years back?
