half inch vacuum hose to from charcoal canister
5rivers
Year and Model: V70 1998 T5
Been thanked: 15 times
Post by 5rivers »
Greetings all :)
Hope everyone is well...
The bracket that holds the charcoal canister on my car is almost toast and in the process of reviewing its condition I noticed the two hoses that go to the canister are cracked at the canister. I have located a replacement for the one hose that is shaped like a large J. It is the other hose that is directed to the back of the car from the canister, has a half-inch ID and is just over a foot in length, that I cannot seem to find. There are no auto parts places nearby that even carry this, and the newer bracket and canister that I pulled from a PNP had the same hose cracked.
Appreciate any thoughts on what might prove to be a useful replacement. Other than ordering 25 feet of a silicone vacuum hose when I need less than 2!
5rivers
1998 V70 M56, silver/grey, has tranny issues, #?# owner, 330,xxx miles, a handy parts car
1998 V70 AT, nautical blue, 2nd owner, 260,000 miles, Sold
1998 V70 AT, T5, forest green, 3rd owner, 172,300 miles, Mimas 16" rims
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
NAPA has hose by the foot. They practically never have what's ideal, but they always have something that will work.
FireFox31
Has thanked: 159 times
Been thanked: 303 times
Post by FireFox31 »
Here's a diagram of the canister area which may be the same as your car. Are you looking for item 11, part 9443309? Mine is also ruined so I got it from FCP.
FireFox31
5rivers
Post by 5rivers »
Thanks for your replies!! I will check with NAPA first and hope they can help :)
5rivers
Has thanked: 2197 times
Been thanked: 1850 times
If it is part #11 it runs from the roll-over valve up to the breather on the fuel filler. Worst case, clean the splits up and wrap it with that black silicon tape for water leaks. It is stretchy and sticks well if you thoroughly clean the old rubber first. That should be fine until you can find the correct hose diameter. The hose should not compromise the roll-over valve as I think it is open at the other end.
