2004 V70 that I'm trying to help a friend out with. I'm using a Vident scanner that is supposed to communicate with all the modules but I get a communication failure no matter what module I try to read.
The problem with the vehicle is no crank. It shows a "severe" air bag problem on the dash. The transmission indicator shows the proper shifter position. If I jump the starter relay it cranks but doesn't start.
I'm thinking that there is something wrong with the computer system since I can't communicate with any of the modules.
It is looking like a CEM high speed CAN bus failure. ?
Help!
No crank, no communication with CEM
- MDK
- Year and Model: 2004 S60R
- Been thanked: 42 times
So, I can tell you from what I've seen. There is a man named Bernie Thompson. He has a YouTube channel called ATS .. automotive test solutions.. who uses an ociliscope to fix these types of problems. You should check that out. I think that's probably what you need to look at this point. MDK
Joelsplace
- Year and Model: 2004 V70
I'll check that out.
Thanks!
Thanks!
Joelsplace
I connected my scope and no signals on bus. I'm guessing the CEM is responsible for that? None of his videos I've watched so far tell you how to tell what device is responsible for bus arbitration and power.
- MDK
You should check out the Dodge Ram 1500 with no start communications failure. He goes way above what I can do. His machine and the system he uses is awesome. He basically starts in plugging modules until he get a can bus signal on the scope and goes ..ah that module is keeping the high speed from communicating..step by step by step.. Joel.. like I said beyond my capabilities.
jking4020
- Year and Model: 1997 850, 2001 v70xc
- Been thanked: 3 times
Remember sometimes with electronic failures it could be something as simple as a bad ground. My mom's 99 V70 XC had a no start problem and we found a bad ground and it started right up. These cars can suck but we love them so.
- 2171 Views
Last post by RickHaleParker
- 1069 Views
- 536 Views
Last post by Hancu
- 8612 Views
- 27 Replies
- 27325 Views
Last post by cn90
