Back in the Volvo saddle again - and an AC question
Forkster
Year and Model: 2005 XC90
Post by Forkster »
Hi all,
For those who may remember me, I used to have a MY04 XC70 which I sold back in 2015. Still miss it. Recently I purchased a MY06 XC90, 2.5T - in great shape too!
A/C question - my AC is blowing warm and when I checked the compressor, isn't spinning at all when the AC is on. I saw the bread clip fix for the older 2.4/2.5 AC compressors and was wondering if because my AC compressor isn't spinning, would re-shimming it fix the issue or is there something more nefarious going on?
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
Try bumping the clutch with a stick to see if it engages. Be very careful not to touch anything else. There are several reasons why it may not be working. Low freon, bad wire, failing magnetic clutch etc......
I'm investigating an intermittent problem with my AC as well on an '04 2.5T. My clutch will cut out after everything is warmed up. I suspect the clutch gap is too wide. Im going to attempt the breadclip bandaid but it's pretty tight in there.
Roger_850T
Year and Model: 854T 1995
Been thanked: 26 times
Post by Roger_850T »
We need to know more details about it not working.
Over time, the clutch can wear, allowing the gap to increase. When everything is moderate temperatures, say on the first start of the day, the clutch will typically pull in and work fine. But when it gets very hot, (like when its >100°F out and the car has been running for a while,) the resistance in the coil goes up, and the 12V source is not able to put enough current into the magnetic clutch for it to be able to pull in and run the compressor. It works when cool, but not when very hot. This is what the "bread clip" fix will adjust for - close the gap up to spec, so the clutch can engage even when hot.
If it never engages, even when cold, this is more likely a symptom of something else awry - no refrigerant, or some other wiring issue. Check for 12V at the power connector to the clutch, and if no 12V then start tracing back. If there's no refrigerant, the low pressure switch will not close, so checking the refrigerant pressure is also a good place to start.
Also note - the breadclip trick can work, but the better option (if you are able) is to disassemble the clutch - there are some moveable shims in there that you can move / remove and accurately set the gap. It's a better fix if you can do it.
Hope this helps!
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
