Hey guys,
I have a 98 s70 turbo 2.3L I need to replace the ECT and have no idea where it is located, so that i can replace it. please help ASAP!
thanks,
Brad Walker
[email protected]
Engine Coolant Tempature Sensor Topic is solved
Guest
I would also like to know where it is. I think mine is bad . would this sensor prevent the fan from coming on completely. when i turn the ac on the fan doesnt come on.
Guest
this is the engine coolant tempature sensor. it is causing my cooling fan to turn on and stay on, like the car is running hot. I have been unable to find the location of the sensor and the easist way to replace it.
digital2
haynes manual for 98 s70 says u need to disconnect radiator top hose at thermostat housing.
disconnect temp sensor wiring plug above the power steering pump also.
