blend door actuators
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
In VIDA, yes. All of them but the driver hot/cold are easily reachable at the passenger side when the glove compartment is removed. That last one is PIA as you have to work blindly with one hand. Still doable though.
What problem are you trying to solve?
- MDK
- Year and Model: 2004 S60R
- Been thanked: 42 times
So, on the driver's side ( LH)....as the car warms up it starts to get hot. The more you drive, the hotter it gets. A retired Volvo tech said that the blend door actuator is stuck open, thus defeating the a/c. I just wanted to see how to go about replacing the motor/ servo. For some reason Volvo here in Cincinnati has unusually high part prices..I found a dealership in Ft Washington PA which is much more reasonable relatively speaking...MDK
vtl
I put this: https://www.fcpeuro.com/products/volvo- ... or-8623354 You need a small 1/4" rachet for torx bit and long pliers, used straight crescent type.
Also the chip is a usual culprit of the failure, it can now be bought in China for a fraction of motor's price: https://www.yoycart.com/Product/39044497258/
- 257 Views
- 252 Views
Last post by BrandynKunde
- 1233 Views
Last post by speedyt5
- 3117 Views
Last post by metalriff
- 14 Replies
- 5651 Views
