2005 Volvo V70 Catalytic Convertor Replacement
volvooh
- Year and Model: '98 S70, '05&'08 V70
- Been thanked: 4 times
I am going to be replacing the catalytic convertor do to a two rust holes that have developed on the convertor near the bracket that cannot be welded. I have a couple questions. First, I would think there would be a gasket between the manifold fitting and the flexpipe fitting, but it appears there may not be one? Second, is there a torque spec for for the manifold bolts?
- RickHaleParker
- Been thanked: 958 times
Gasket
Chassis -424999 Volvo part number 8642449.
Chassis 425000- Volvo part number 30650969.
Exhaust Manifold (cylinder head side) torque spec 25 Nm .
Exhaust system (to the turbocharger (TC)) 24 Nm .
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The mani has a metal gasket, I've reused it without issues - mine was a non turbo
After the cat is a 'paper' gasket to replace. The downpipe studs may last more, the ones after the cat were melted on mine. Just tighten 'tight' without over doing it. If you are replacing the nuts, may want to use black coated exhaust ones which don't get stuck. Shiny ones get stuck
- GlennG2759
- Year and Model: 2006 V70 NA
- Has thanked: 112 times
- Been thanked: 17 times
My cat was leaking exactly where yours is. I was able able to get some welding into the bracket attachment points on the cat. The reduced hole size I had left I filled JB Weld high temperature metallic paste. 1 & 1/2 yrs. and 18k miles later still holding up. If you haven’t bought a cat yet might be worth a try. Good luck.
- 207 Views
Last post by vtl
- 4422 Views
Last post by MadeInJapan
