09 S60 windows open themselves Topic is solved
Dave in Maine
Year and Model: 2009 S60 2.5T
Been thanked: 3 times
Post by Dave in Maine »
More precisely, when I'm closing the windows, they go all the way closed and immediately bounce back and open themselves all the way. This happens occasionally - no way of predicting when it will happen. It happens more frequently with the driver's door window, less frequently with the passenger's door window. It happens when I use the "turnpike tollbooth" method - i.e., give the window switch a short pull to close the window and it's supposed to close all the way.
I can get the windows closed if I hold the switch up until the window closes. It will seem like the window is trying to "rebound" and open itself, then it changes its mind and stays closed.
What's my problem and how bad of a fix is it?
1996 850 Turbo Gold Edition, 7 years' reliable service and >220k mi, sadly now gone
2009 S60 2.5T, sent away after taking me down Via Dolorosa. Happy to be rid of it.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
Try calibrating the controls.
leapdragon
Year and Model: 2007 XC70
Has thanked: 12 times
Been thanked: 31 times
Post by leapdragon »
When I bought my '07 XC70 recently it had this problem on the driver's side door. I tried a bunch of different fixes from YouTube (including hold for 10 seconds at bottom, hold for 10 seconds at top and pull fuse right before top, then some ignition stuff, then reinsert fuse, roll up, I forget the whole process) BUT none of the "quick" fixes I was able to find fixed the issue.
In the end, I had to fire up VIDA and explored until I found the window module calibration in the door module. Once I opened that up, click, click, got an OK, and then after that it worked without issue.
Point being: it's possible that your modules need to be told once again just where the top position is after the car has aged a little. The question is how to tell them.
Hopefully either you're able to get one of the YouTube fixes to work (I wasn't) or you have a VIDA setup on hand, or know someone that does. :-|
jonesg
Post by jonesg »
Should you need, I have vida in Maine, Island Falls, north of Millinocket.
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
Fought with my passenger for a while doing a similar thing. Ended up being a bad relay on the PDM (only showed up on carsoft/vida)
04s60 2.4
04xc70 2.5t
Dave in Maine
The YouTube solution worked on the first try!
Love the Russian-accented voice synth.
