2010 XC70 T6 (104k) stopped charging and the dash lit up. Pop the hood and you can see that the alternator is not spinning. engine off and you can spin the couping by hand. From other forums and Youtube it sounds like it is the Alternator Clutch Gear and bolt attached to the READ unit (https://www.fcpeuro.com/products/volvo- ... t-30750136). Maybe just the bolt is loose letting the clutch gear spin without engaging the actual READ unit?
So the youtube video -
suggests you need a special tool to replace the clutch gear and bolt. But I can only find a tool that replaces the clutch gear on the alternator side, and not on the READ side.
Anyone have a walk through and tools list for tightening the bolt on the read side? Is that a reasonable assumption for why the couping and alternator CAN turn, just are not turning with the engine on?
I was planning to order intake gaskets, new bolt, and new clutch gear sprocket. Anything else?
2010 T6 - Alternator Spinning - READ side
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
The pulley on the READ side is attached by a bolt.
The reason that the pulley gets loose is because the clutch pulley on the Alternator stops working and it backs off the READ pulley
So you will need a Tool and a pulley for the Alternator
Good luck
Paul
Good luck
Paul
I have the exact same problem with the bolt being loose on the clutch gear(30750136)
Is their a part number, picture, website, or any information at all about the tool you need to hold the gear while tightening the bolt?
I cant find any information so any help would be greatly appreciated
Cheers
Cheers
ironbrick
- Year and Model: 12 XC60 T6/07 S80 V6
- Has thanked: 2 times
- Been thanked: 3 times
Thanks Paul. Your posting is still giving back!pgill wrote: 09 Jul 2021, 10:19 The pulley on the READ side is attached by a bolt.
Good luck
Paul
Anyone know if the factory alternator comes with a new pulley?
- pgill
The Bosch rebuilt AL0870X does come with the overdrive pulley installed (LR2 Mike bought one recently)ironbrick wrote: 03 Oct 2024, 06:03Thanks Paul. Your posting is still giving back!pgill wrote: 09 Jul 2021, 10:19 The pulley on the READ side is attached by a bolt.
Good luck
Paul![]()
Good luck
Paul
- pgill
Brennen wrote: 04 Jan 2022, 12:50 I have the exact same problem with the bolt being loose on the clutch gear(30750136)
Cheers
I am not sure if you understand the failure mode.
1. The Alternator Overdrive Pulley (clutched pulley) seizes up
2. The drive pulley 30750136 on the R.E.A.D. loosens up because of the Alternator loosening the drive pulley instead of FREEWHEELING
Apologies if you already knew all of this.
But you are asking about fixing item #2 but if you don't fix item #1 then you will continue to get the failure mode.
Having said that if you already have all of the parts (i.e. a rebuilt Alternator) and your concern is just holding the drive pulley 30750136 when installing the bolt.
* My recommendation is to just tighten the bolt.
* The R.E.A.D. is connected to the crankshaft so the engine is effectively holding the nut that the bolt is connected to.
* The special tool would be to hold the flywheel so that the engine doesn't spin.
* But I don't this it is needed.
Good luck
Paul
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
How to potentially prevent damage to the READ Unit.
- 599 Views
Last post by FrickinHek
- 723 Views
- 362 Views
Last post by dr1vereye
- 731 Views
Last post by Jonatan
- 2154 Views
Last post by oragex
