V60 cross county winter wheel compatibiity
JH4music
Year and Model: 2016 v60xc
Post by JH4music »
Hi, I have a 2016 v60 cross country with the 18” “NESO” wheels and 235/50/18 tires. I found a set of 215/65/16 winter tires on the TELLUS rims from an 04 xc70. Diameter is close, offset is close, bolt pattern correct.
Will a 16” wheel clear my brakes?
Is the center bore the same?
Will tpms sensors designed for the 16 v60 work with the older rims?
Do I need a programmer for new tpms or will the car be able to adapt to the new ones when I swap tires/wheel?
