My passenger side bellows is leaking and I belive the rack seal is shot.
I have the rebuilt rack and access to outer tie rods if necessary.
I am sourcing power steering pressure hose 0-rings (green) and I would think I need 2 for each line.
The pump and resevoir show no signs of being compromised.
What other items should I consider prior to the rack install?
A link to the procedure would be great!
Thanks and have a good day,
Tommy
replacing steering rack questions
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Look into installing a power steering return line filter - if that seal is compromised there "is" junk in that system. I'd flush it afterwards.
@Abscate likely has something hanging around on replacing one, think he did one within the past year or so.
tommylg
- Year and Model: 1998 s70 glt
- Been thanked: 3 times
I have the 3 fresh o-rings on the way,
wizechatmgr, is that filter an add-on and a safety precaution?
I spoke w/the tech about a super flush of the power steering system to clean out any debris from the old rack.
Appreciate it,
Tommy
Appreciate it,
Tommy
tommylg
Prior to taking th eS70 to the shop, I am going to plastic film wrap the passenger side boot - short term - and attempt to remove the fender liners, PB Blaster all bolts/nuts/screws and.
What am I looking at? Is there 6 rivets per side, and the top is just clips I need to unclip?
Any replies would be appreciated.
Thanks and have a great wknd,
Tommy
Tommy
- 1248 Views
- 1666 Views
Last post by jonesg
- 5382 Views
Last post by mecheng
- 1139 Views
Last post by jeffsws
- 26 Replies
- 5416 Views
Last post by hausmeister
