CEM Failure Symptoms
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
Hey guys, I've noticed when connecting my DiCE sometimes I'm unable to read the vehicle. Sometimes it connects yet all modules show no communication. Sometimes, I actually get a "BRAKE FAILURE" message on the DIM when running DiCE when everything connected ok. I've never received the BCM fault in normal vehicle usage. The other day when I was running VIDA my car randomly started idling ~1000RPM and I got a P0507 code. That was the first time that ever happened. Also in the past I have seen CEM-E000 show up in the fault code tree.
Is any of this normal behavior, and is any of it evident of a bad CEM? It seems to act funky when it has the load of DiCE running on it. It is a 2004... I've been using dice more lately to try and chase my engine surging issue hence seeing the issues crop up while troubleshooting.
04s60 2.4
04xc70 2.5t
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
2004 v70,
ABS lights up whenever I connect VIDA, but goes away once I unplug the dice.
Thats usual behavior with mine.
I don't run the engine , I just put the battery charger on it when connected.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I was getting a "brake" message when connected, it was a faulty relay but I had the older 01-03 CEM model. People were saying this could be because of a BCM "partial" internal issue. For the CEM the easiest is to look with a flash light under the dash for dry traces of water on the module. You may also try to look outside at the connector, but need to remove the wiper arm which most probably is badly stuck - don't wiggle to remove, it takes a strong wiper puller
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
One test could be to use a hair blower on the CEM and see if your problems arises faster. If it's not a permanent error ofc.
BMW 540i 2002
S70 Base 2000
