I just want to verify from those who know whether the alarm siren is supposed to go off when the alarm is triggered.
I just replaced the siren module (bought from Erie Vovo). To simulate the alarm, I rolled down the drivers window, closed all the doors and locked the doors using the FOB. I reached in and opened the drivers door from the inside. Waited 10 secs and my side marker and turn lamps started flashing. But no audible siren.
Erie Vovo is sending me a replacement module so we will see.
2004 XC70 143k mi
Alarm Siren Question
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
If the doors are locked and alarm engaged , yes it should sound.
Many salvaged alarm modules are already toasted by the battery acid inside the module.
If you get one that works , change the battery asap...unless its a new unit in the box.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
As above, when you lock the doors, do you see the red dash LED blinking ? May also want to drive the car for a while to have the internal siren battery recharged, just to make sure, and check again the siren fuse is good
- 2170 Views
Last post by Sailsman
- 679 Views
Last post by nascarmarc
- 2692 Views
Last post by IdahoBob
- 1103 Views
Last post by vtl
- 1535 Views
Last post by Snordbe
